I have an 07 Titan SE 4x4 with a 2 inch PRG level. I have been looking for about a week for a set of 20's. I was told the OEm backspacing was about +35 but they said i couldn'y run Nitto Grappler in a 305/50/R20 even if i had the correct offset. Could someone please give me some info.
By the Way.. I don't have a leveling kit on my titan.. I would go talk to someone else.. I have been running this setup since Jan.. I have had no problems at all..
Discussion Starter #4
Thanks...I have seen lots of guys on here running those tires but i am glad actually hear there shouldn't be a problem. By the way what offset and or backspacing are your wheels?
They will fit, depending on the wheel offset you might get a little rub when you crank it hard. I had the setup on my truck.
Theyll fit I also had this combo.
I have the Diamo 15 Karat 20X9 rims.. I have plenty of room.. Even with the rear end squating this weekend with a 1000lbs of junk in the bed, they still didn't even come close to rubbing..
