1 - 17 of 17 Posts
One question can i fit a 315/70/17 on a 04 Nissan Titan SE KC. With a leveling kit or would i need a 4 inch lift. :redblob"
I have an 05 cc 4x4 big tow and tehy fit under mine without the leveling kit
The 2wd is real low in front, but with a 2.5" level spacer they will fit....BUT with factory wheels and "Pinch weld mod"...Do a search...
Ill get one this weekend ok. they pretty much take up the wheel well but look great
This is my 04' 2wd with just a 2.5" PRG level spacer up front and factory O/R wheels....Pinch weld and much more done, no rubbing at all...
How much did the pinch weld cost?
Nothing...I did all the work myself...
Banned
my little sister could do the pwm with a sawzal (sp) its really not hard so a search for pinch weld mod simplified
Do yo think it would firton a 4x4 with PRG 4 inch lift?
I have a 2wd with the leveling kit and the 17" off road wheels with BFG 315/70/17 tires. No pinch weld mod here. The only rubbing is when I go in to the drive way at a side angle and turn hard.
Discussion Starter #13
So pinch mod is just something to say so you sound cool? And a 315/70/17 will fit on my titan 4x4 no problem then when i get it done ill post pics. :redblob"
Banned
Im not saying that. Actually every truck is different. Some people dont need to do the pinch well mod some do. You might be lucky and not need it done.
...08 Pro4X...
:hi: Dave!
Discussion Starter #17
they call it the pinch weld b/c they use the pinch welder to put it on and you just cut it off! but the quality of a shop might be a littler better but in reality you just need a sawzall to get it off
http://www.titantalk.com/forums/titan-faq-howto-area/48315-simplify-pinch -weld-mod.html
Not a big fan of the sawzall to make a truck look good. If the tire dont fit ill just lift it more, but thanks man.
1 - 17 of 17 Posts
