1 - 8 of 8 Posts
Will these fit or will they rub? Next question would be will 31.9 fit without rubbing.
33" wheels? Bling bling. :)
In all seriousness, the Pro4x comes with 33" tires stock. No issues with rubbing.
2017 texas titan 4x4
33s should be stock on all. My 2017 sv stock size is 275/60/20, which is a 33. I put 275/65/20 on recently, which is a 34.
No level or lift and only rubbed in reverse turning left on a lean at one certain spot of the turn. Trimmed the corner of the mud flap and no more rub
2wd Titan sits lower than both 4x4 models. Might be a problem.
Ground clearance...
2wd = 8.3"
4x4 = 8.9"
4x4 Pro4x = 9.8"
ohhh. i didn't know that. have to go wide and low than
The ground clearance numbers are at the rear pumpkin (differential housing).... That has to do with tire size. So any Titan with tires smaller than the Pro4x 33.2" tire will have lower ground clearance. Has nothing to do with the height of the suspension, although I do know the 2WD is lower than the 4WD models. I would bet the 33s will still work on the 2WD models as long as you stick with the stock width. If not, grab some Bilstein 5100s and a small spacer and you'll be set.
1 - 8 of 8 Posts
