Shouldn't be a problem with the correct offset/backspaced wheels. There are several trucks with 37's. It's not so much the hieght that gets you, but rather the width of the tire you choose. Might require the pinch weld mod.
Do you have the stage 1 FT or stage 2??? If you add new Upper Control Arms and SAW or Radflo shocks with a custom spacer, you can get another 1.5"++ of lift in the front without changing anything else. With those mods and the pinch weld mod, you shouldn't have any problems.
