Pop off the plugs in the ceiling liner above the rear window. You'll see the nuts holding the light. Remove them and the light will come off.J_RoD_808 said:hey guys feel like a loser askin this question but how do you remove the 3rd brake light??? i thoght it was pretty straight foward so any help thx..
You will need a a deep 8mm socket. They are kinda tricky becaause they are at an angle.J_RoD_808 said:thx... well i figured it out myself... i was jus tryin to yank um off didnt even think about the plugs in the ceiling... hahaha
Since the bolts are at any angle, would you suggest a magnetic deep socket?AF-Medic said:You will need a a deep 8mm socket. They are kinda tricky becaause they are at an angle.
