Your only choice is a 6 inch bracket lift or the prg extended travel package that gives about 3
Sent from my Samsung Fascinate using the auto guide app
Rancho's "4 inch" lift is actually a little over 5" of front lift paired with 2 inch rear block. You will be "nose high" by nearly an inch with this. If I were purchasing this kit, I'd also get the C10 deavers from PRG and Have a level riderancho says they have a 4 in lift but who knows it will ride a little rougher but thats what happens when you lift it lift = stiffer
Its not that.easy u would have to have a longer than stock but shorter than full 6 inch spindle made which would cost money. U would need like layer said a 2 or 3 inch lift spindle.This may just be a dumb question, but what would be the problem with having a shop either make a shorter spacer for a bracket lift or just shorten one from a kit? (I am not thinking of doing this, just curious)
Nothing.. If there was a spacer for the 4" Rancho then folks could go with Bilstein shocks or keep there stockers for a short while, keeping the cost down.This may just be a dumb question, but what would be the problem with having a shop either make a shorter spacer for a bracket lift or just shorten one from a kit? (I am not thinking of doing this, just curious)
