4" of the lift?? prg/hooligan anyone else
ok this question is for greg or hooligan mainly, and anyone else who is a suspension guru, you can throw in your thoughts too. let me just start off by saying that i'm a complete suspension noob. basically, i want a kinda mild lift for now, i eventually plan on getting the mid-travel kit from greg, but that won't be for a while, so until then, here's what i was thinking, tell me what you think or what you'd change if anything or if there's anything i might be leaving out...fyi i have a cc 4x2
4" cst spindles
2.5" spacer
looks like maybe the 2.5" deavers in the rear
maybe a 1" or 2" block and carrier bearing if needed
prg uca's
i'm thinking either saw's in the front and either saw's or 2.0 or 2.5 radflo res in the rear (not really sure on which of these setups i should go with, any input is greatly appreciated)
Pro Comp Extreme Alloy Series 7089 wheels Specs: 18x9, 5 on 5.5 Bolt Pattern; Backspace = 4.75 in
not sure on tires, kinda a toss up between these, and if they would fit or not:
ProComp Xtreme A/T 325/65/18
Toyo Open Country A/T 325/60/18
Either the Nitto Terra Grappler 325 or 355/65/18, not sure if the 355 will fit or not though
basically the tires are still up in the air, any suggestions as to what would fit better? i don't mind if they stick out some to give it a more aggressive stance
anyway, i think that's all the stuff i'm looking at, any opinions, suggestions, or anything else anyone can help me out with as far as this setup goes, or if there's anything i could change in this setup to make it any better??
thanks guys
evan
4" cst spindles
2.5" spacer
prg uca's
thanks guys
evan
