1 - 10 of 10 Posts
Hey guys, I have a little problem. The lights that light up the 2 wheel drive and the 4hi and 4lo buttons went out. For a while it seemed to only be the 2 wheel drive that was out, now all three are out. I tried messing with the dimmer switch and it doesn't fix it. Is this bulbs that need replaced or would it be a fuse. I can't seem to find anywhere what bulbs these would be to replace.. Any help would be appreciated!!
I have been looking through the service manual, and I can't find the bulb. I don't even know if a bulb can be replaced on that. I will keep looking, but without taking the dash apart I am not sure how much help I will be.
me to, my heater control backlights on the knobs, and the backlight on the window switch have all gone out too...=/
There's a few way to fix it. Radio Shack bulb #272-1154 Bi-Pin Lamp 12v or you could use LED both of which require soldering.
(If using LED you'll need a resistor or they'll blow). Of course you could buy a whole new switch.:D
ok you know which resistor to use? And where to put it?
1 - 10 of 10 Posts
