good question... where did you buy the parts? link? subscribed...
Oops, I overlooked that part... :rofl: yup, the 4" spindle will not work for 4X4... hhhhmmm... I guess you could just get extended length coilovers w/ PRG UCA's, or a 2" spacer and the PRG UCA's... The PRG UCA's uniball mount and tubular design actually provides 1" of lift up front, along with the 2" leveling spacer, you should have a reverse rake... Then slap on a C10 Deaver pack and that'll give you the 1" needed in the rear to level it out again.Spindle kit on a 4x4? I didn't think that they worked for 4x4s. And to be totally honest im not concerned about the ride that much, I'm young and it reminds me that im in a truck not some luxury car, so i don't mind some stiffnes in the suspension. But thats just me.
Oh sorry... thats why i wrote im "pretty sure". Well regaurdless the setup i described up there would still be best for you if you dont want to break bank and still have a sweet ride.PRG UCA's will lift the suspension height by 1" due to the configuration of the uniball mounting joint...
Where did you hear this? If they did, you could bet Greg would be listing it as an additional benefit.PRG UCA's will lift the suspension height by 1" due to the configuration of the uniball mounting joint...
Thanks for the clairification brother!Strait from PRG:
"Using these arms will not raise the truck all by themselves but will allow a longer shock to be used for more height without the upper arm hitting the coil bucket or they can be used with a lift kit and a small spacer to get more height."
Linky
