Morning All. I have tried searching the forum but have not found anything conclusive. I am having an issue with the 4WD system disengaging on my 2009 Titan LE Crew Cab 4WD. You can shift from 2HI to 4HI and it will shift immediately (You can feel it has engaged) But when you shift from 4HI back to 2HI it takes a long time to disengage. The 4WD Light will just flash. The first time this happened it took 12kms to finally disengage. I do not see anything that could be causing this issue and the fluid is where it should be and nice and clean. I found that downshifting a couple gears causing a light jar will disengage the 4WD. I am assuming this is a bad solenoid? I cannot find a part number for the solenoid either. Any insight or suggestions would be very appreciated as I can only assume this will get to a point of either not disengaging or not engaging altogether.
Thanks kindly!
EDIT: I forgot to mention that a week or so ago I switched from 4HI to 2HI when I was off of snow and ice and the 4WD status light started flashing like normal but then completely disappeared and a light showing "4WD" Lit up and went away after I downshifted and brought back the 2WD/4WD Status light.
Thanks kindly!
