I have a 2004 Titan SE 4wd with 68k. I bought it new, and have just been experiencing this problem with the most recent snow. My rear wheels start to drag when reversing direction in 4wd. It happened to my wife first, but this weekend I witnessed it. While in 4wd I backed out of my garage into the snow, did a 3 pt turn and went to back up the hill back to the garage and the rear wheels were locked up and sliding. The front wheels were pushing. It happened a few other times (usually shifting to reverse). No warning lights or sounds. After shifting back and forth from D to R it would kick in. 4Lo did the same thing. Once I got going, 4wd worked fine and I drove on snowy roads without trouble. Even shifted in and out at low speeds without issue. 2wd still works great -- VDC and all. It always happens when you really need 4wd reverse.
I called the dealer, and they hadn't heard of the problem before. Mentioned that it might be the front differential, but they would have to troubleshoot and it would most likely be expensive. Would it be front or rear diff? Transfer case? Even brakes?
