If you have ABS light, it won't engage. If you have an abs slip vdc light its probably a worn out wheel bearing messing up the sensor and a connection issue. Most common being a leaking muffler burning off the RH wheel sesnsor harness. Transfer cases generally dont have a problem unless its a leaking rear seal
