Hey guys,
I've read the 5100 install/tips thread multiple times over and I'm ready to pull the trigger on this. My oem suspension is SHOT and it's time for an upgrade.
I just want to make sure i'm understanding everything correctly and that i'm ordering everything that i SHOULD/Need.
04 crew cab 4x4
5100's 2 front, 2 rear (.5")
moog springs for 08 4x4 (.5'')
1.5" spacer
should give me a total of 2.5" in the front and in theory i shouldn't have contact from the stock uca's. Correct?
prg camber bolts
2" blocks for the rear, coupled with the 5100's
This should raise me up and leave me level correct?
I have 275/65/18's now so In theory I should be able to run 35's after the suspension upgrade correct?
Is there anything you guys recommend replacing while I'm under there, or anything I'm leaving out?
I really just want to make the orders, have everything ready to go so I can make an afternoon of it and not be stuck 'needing' to order something i left out haha
Thanks!
Z
04 crew cab 4x4
1.5" spacer
prg camber bolts
Thanks!
Z
