1 - 11 of 11 Posts
Hey guys, Im new here so HEY!
Im planning on purchasing a 6.5-inch maxtrac spindle lift for my 09 Titan, but I have a few questions!
1. Do I NEED new UCAs for this lift? I'm currently running 18x9 -12 offset fuel assaults with a 1.25-inch spacer so I have more of an aggressive stance. Do I NEED new UCAs with this setups?
2. If i already have a 2.5" leveling kit on would I be able to stack the spacers to achieve 8.5 inches of lift or would that be stupid?
3. If I could stack leveling kits what would be the best way to level it out in the back so I'm not squatting
4. IF I can stack lifts and end up achieving 8.5 inches would I be able to rock 37s?
Thanks guys! Please help me out!!
Another one of these...
Don't stack your spacers.
Yes you will likely need different upper control arms
no you won't get 8.5"
yes you can run 37's, you will have rubbing and scrubbing
I apologize for asking? I appreciate the help though Ive just heard a few different things about whether or not you needed new UCAs. Thanks. Oh also do you know if you could stack a bbody lift on these spindle lifts?
You could do a body lift on top of a lift, you would just need more components, probably longer brake lines and stuff like that.
Check this thread out. It will probably help you out more than any active users can...
http://www.titantalk.com/forums/tit...48207-ultimate-what-tires-will-fit-guide.html
highly recommend the UCA upgrade...preferrably DK's!
if you want more height i suggest going coilovers. double check the Maxtrac 6.5" kit as they claim 6.5" but really it's a 6". believe me, i emailed Maxtrac and they're not sure why some seller's are posting 6.5" when it's a 6". with the 2" spacer that Maxtrac includes i have the coilovers set to 2" so i'm about 8.5" of lift!
even with my lift with 35's i scrubbed big time but after a Major PWM no more scrubbing. 37's will definitely scrub even more but with a 3" BL you should be good to go!
Hey man love the truck. One of the reasons I am going with the maxtrac is due to the price and 500 dollar UCAs dont quite fit the budget right off the start. Is it like an ABSOLUTE MUST HAVE? How long could I run stock UCAs and be okay with just the 6.5 inches of lift?
for some reason people either do get CBC or they don't. just get the Maxtrac installed and if it hits you'll need to upgrade your UCA's. With mine you can see how close the CBC is
I have the same lift spindles. But instead of using the spacer up front I went with bilstein 5100s on middle notch with moog 81194 coils and got 8 inches of lift out of the front. I too had to do the pinch weld mod but now barely rubbing with 35s on 22x12 -44 offset
1 - 11 of 11 Posts
