1 - 11 of 11 Posts
I have an 05 titan and want to lift it as much as possible for as cheap as possible. i want to get the rcx 6in suspension lift , but was wondering if i could add additional 3in strut spacers??? thanks for any help
First off I'll say I've never installed a lift, but usually that kit comes with a 6" spacer to go on top of the factory struts. You can't put a 3" spacer on top of a 6" spacer. If you add coilovers for a 6" bracket lift and then a spacer maybe along with aftermarket upper control arms to stop the coil bucket contact, but I'm not sure about the cv angle there. I think you would be better off finding a higher lift from pro comp or whomever makes one or going with a body lift on top of the 6" RC lift. Do yourself a favor and save up the money to do it right the first time, or you will spend it on repairs.
The RC 6" lift is just a 6" spacer on top of the coil (along with the bracket hardware, etc). You can't add another spacer on top of that. Go with a bigger lift or get a body lift.
Maybe check out those bullet proof 12 inch lifts if you're going for such height...OR do the 6" RC lift and just go with some body lift for that extra bump in height.
thanks everyone i think im going to settle for a rc 6in lift only.
You'll be happy with it. I went with a 6" lift on mine thinking it wasn't going to be all that much and it is plenty tall.
Couldn't find a good spot so I'll just ask here if that's ok Az?
What kind of lift is this?
Sent by my thumbs using whatever means necessary
Looks like doodge. First off, that truck has a solid front axle, the suspension is different than the titans that have Independent suspension up front. Not at all relevant to this discussion, and as far as I know there are no manufacturers of a sas (solid axle swap) kit for the titan.
How'd it go? U got pics? How'd it go with the steering column and does the suspension and control arms seem beefy enuf? Not sure much off-roading u do.
That's a dodge!? A solid axle!? I'll be damn! Thx for helping us out captain obvious
No problem. You didn't seem to know the difference, from my impressions.
1 - 11 of 11 Posts
