It's alot cheaper to do your own... Frozen Rotors, R1 Concepts, etc, are MUCH better options than the OEM junk brakes.. While you're changing your brakes, it's a good idea to bleed the lines too, since you'll likely need to do it before 100k miles anyway...
From your description, sounds like you should change your Serpentine Belt.. The Idler Pulley might also need to be changed but it's easier to change the serpentine belt first then change the pulley later if it still squeals. Goodyear Gatorback should be a good alternative to the OEM belt.
Here's a write-up I did on changing the drivetrain fluids.. My Differential Gear Oil is different than yours, so make sure to check the recommended viscosities in your Owner's Manual instad of following the ones I used:
References for Changing Fluids.... - Nissan Armada Forum: Armada & Infiniti QX56 Forums
