8" fabtech?
765 Views 4 Replies 3 Participants Last post by  KUSTOMZMAN1
ok i cant find anything about it but i heard you can put a 2" or 3" spacer up front and blocks to match in the rear ON TOP OF the fabtech lift. does anybody have this? or see any problems with it?
Mine is something like that. Can't really tell from the picture because the driveway is sloped but I don't have the spacer. I have coilovers cranked about 2 inches, bigger block in rear and deaver pack, about 8 1/2 inches of lift.
are you 4wd?
if so any cv problems?
No, it's 2wd.
I had the fabtech on mine, then upgraded to coilovers and a spacer (the old daystar one) the front was fine and just able to get it aligned. In the rear I had Super Springs (helpers) with the fabtech add a leaf and 2" block...and it sat perfect....but rode rough because of the helpers. So I removed them and added a pro comp 3" block and had nasty axle wrap, sold the truck a week later...but I would have orderd a deaver complete leaf spring to help with axle wrap. so to answer your question it can be done just make sure a good shop does it and you may need to have a coil over up front so your not stacking a spacer onto a spacer...good luck!
I didnt have any cv problems either..
