1 - 2 of 2 Posts
I was having problems with my A.C the blower motor was fine so I replaced blower motor resistor and still had problems with the power of the A.C so I moved this piece next to actuator it was loose so I turned a lil and air got powerful and cooler but after that truck started missing and trying to turn off unless I was driving but once I slowed down car would try to stall out anyone have problems like this ? 2005 Nissan Titan
Super Moderator
Are you sure your problems are related to what you did? Unless you pulled out or loosened a wire when you worked under the dash, your problem sounds a lot like your IPDM or your hose from the airbox to the throttle body has come loose. I'd check those three things, air box/throttle body hose connections, IPDM, then loose wire in that order. I'm betting it's the air hose connection, easy fix.
1 - 2 of 2 Posts
