a little help
592 5
ok im a little confused. i am considering the PRG 2" leveling kit. evrywhere ive looked im seeing that i need an alignment but have to get bolts from the dealership. one guy said $350 another said $70 for them, what all is going to be required to do it right and what is a round about estimate?
thanks in advance, Josh
1 - 6 of 6 Posts
how many miles do you have? I think some of the guys have gotten the camber bolts for free by getting an alignment which is covered for the first 12,000 miles.
I just did mine about a month ago. It's an '06 and yes, it needed an alignment afterwards, but the toe was all that required adjustment. No caster or camber adjustments were required. And yes, as was stated, the dealer should do the bolt install for free under the TSB if the truck needs them for proper alignment and has less than 12000 miles. Chances are, you won't need them.
Have the camber/castor checked, you might not need to adjust those, and have the toe set...
1 - 6 of 6 Posts
