1 - 3 of 3 Posts
Ok was out doing some work on the 2010 Titan SL 4WD and noticed some oil on the top of the wheel fender inside engine cavity. Upon further inspection it looks like the ABS actuator and electronic unit is leaking some oil. Real hard to see in there but that looks to be the culprit. Is there a common issue with these. Cheap fix easy fix? dealer fix?
Any input would be appreciated. Thanks
Discussion Starter · #2 ·
This may help. Seems to be leaking out of centre of black thing on module. This is not actual one just similar to what i have.
My guess is the front diff vent puked a little oil there and this is just a coincidence.
1 - 3 of 3 Posts
