1 - 11 of 11 Posts
i think I need a reluctor ring for the back passenger side . The teeth are not straight there's a slight intention as if something where rubbing on it as it turned. Anyone know where I can get one cheap? Or is there a chance the one I have will work?
the build date was 07/04 do you know the date of the split? Ive already had gotten one axle that flared out on the bottom and was too big so now im back to square one.
I’m having the same problem with my 2013 Titan. E brake cratered and ripped off about a 1/4 of the teeth. Any suggestions I would like to fix it myself?
OReilly auto (and others) have the part available. As to how to fix it, that's another story. Assume it must be pressed on the axle, which may not be easy.
There is a great Youtube video that walks you through removing the axle, cutting off the spacer, bearing and reluctor ring.
you will need to press everything back on.
1 - 11 of 11 Posts
