I have searched the forum and read a lot about the ABS SLIP light issues and the speed sensors and fluid level.
Fluid is at max.
hooked up to a buddies expensive reader that reads ABS and it is showing sensor codes on all four wheels. it is also showing some steering angle sensor code.
I can't believe there is any what all four sensors could have gone bad at the same time. Is there some control module that could be doing this?
Thanks all.
BOB ROSE, did you ever figure this out? Ive used the workshop manuals and i believe my control module is bad. Ive found them for like $850 but afraid to pull the trigger incase it doesnt fix the problem. I just curious how many on here have replaced their ABS control module.
I’ve replaced all the sensors. My problem is it keeps giving me a wheel sensor code but it’s sometimes the right and sometimes the left. It’s changed over time. There are no other codes. It’s gotta be sending erroneous codes from the module.
