Abs/ slip light won't shut off. I had a bad front bearing and replaced it, topped of my brake fluid, still on. It shuts off maybe 5% of the time otherwise it's constantly on and the 4wd won't engage. Any suggestions are appreciated.
Check the ABS connector at the hub. May have messed it up while you were changing it.
did you check the code?
I have a similar intermittent issue (whenever I turn my wheel full lock left), and it never throws codes. Pretty much everything lights up, to include the brake and 4wd lights from occasionally. But still no codes. I'm assuming it's one of the connectors is either loose, or clogged up, but I've just been too busy/lazy to pull it apart and check it all.
I've looked at both cables while someone else turns the wheel back and forth though and it doesn't look like anything is stretching, or pulling, or pinching...so I don't know honestly.
I checked for codes on my truck when the SLIP light came on and didn't have any codes.
· Super Moderator
On the slip light , check the rear axle seals and see if they are leaking ...
