In most Nissans, if those lights come on in unison it has to do with brake fluid levels. Have you checked that?
Fluid levels are all good and topped off.In most Nissans, if those lights come on in unison it has to do with brake fluid levels. Have you checked that?
At all 4 corners. They were all very similar according to my multimeter.You check the resistance of the ABS wheel speed sensor itself on the front left?
I will give it a try and get back to you. ThanksNot sure if my previous post regard the same lights coming on and staying on after I replaced my clock spring when my left side radio and bluetooth controls failed but you can certainly try:
1) Crank truck
2) Turn wheels all the way to right and then left a total of three times
3) Drive truck at least 50 feet and the clock spring will automatically reset
Good Luck!
Unfortunately that did not work for me. This is the longest time the lights have been on for now.Not sure if my previous post regard the same lights coming on and staying on after I replaced my clock spring when my left side radio and bluetooth controls failed but you can certainly try:
1) Crank truck
Good Luck!
