Hello,
i have read a lot of the forums about the slip, abs light being on and the 4x4 not working. The conclusion that a lot of people came too is that one of the abs speed sensors is bad.
I have visually checked all of the sensors and they look good.
My question is their a way to check the speed sensors to see if they are bad.
I live about an hour from a nissan stealership and i want to see if their is a way to check them at home.
I did some research and it said to check the ohms on the speed sensor plug. has anyone tried this before and do you know what it should read.
thanks in advance
i have a 2006 titan 4x4 crew cab 5.6
thanks in advance
