I really need help! My ac condencer fan isnt working and my truck keeps running hot when setting still. Checked all the fuses and relays and they are good even changed out the condenser fan fuse just to be sure. I can straight wire the fan and it will come on. So motor is good. What else can be wrong? Please help me! Getting very hot in mississippi!
It doesn’t come on all the time. It’s based on heat and AC high side pressure.
This video shows a quick test you can run the truck through to test that the fan functions - which will test the fan, fuses, and relays. If you do this please tell me if you feel the air blowing toward the front of truck or if it’s being sucked in and blowing toward the engine.
If you ran this test in the video and it didn’t come on, but does come on when straight wired, Then that sounds like a relay problem. Clearly, the fan motor is working.
Related Threads
Nissan Titan Forum
3.9M posts
142.8K members
Since 2003
Nissan Titan Talk Forum is a community for truck owners to discuss the Titan Cummins, Warrior, Midnight Edition and more!
