1 - 2 of 2 Posts
Help please? Have an 07 Titan, replaced VCB, BLOWER MOTOR. When I'm running air or heat on floor to defrost and switch to vents there is a knocking, varies from around 5 to 15 seconds, and when I turn engine off it will do same? Also when I turn fan on the relay next to blower clicks, that I understand, problem is when I turn all the way on high (last setting) same relay clicks again and blower motor quits till I turn diel back one notch! Any ideals that can help? Please and thanks!!
Its your AC actuator door. common problem. Happened to me twice and thankfully it was still under warranty. I've heard the process is a PITA.
1 - 2 of 2 Posts
