1 - 8 of 8 Posts
Vendor
Let's face it, you love your Titan, and want it to look cool and still be functional at the same time. Adding a set of EGR Bolt-On Style Front and Rear Fender Flares will help you to accomplish this.
No matter if you have factory size tires or larger, these fender flares are custom-designed for a perfect fit. EGR Fender Flares built to last from high-impact acrylic with UV-blocking layer to prevent sun damage. Installation is easy thanks to the no-drill fixing system.
With EGR Bolt-On Style Front and Rear Fender Flares on your Nissan Titan you'll get rugged, aggressive look, that will set you apart from the rest. If you're looking for top-of-the-line quality and durable add-on, EGR Fender Flares is a perfect choice!
does this also fit the longbed titans or is a different part#?
Wish they had them for the first gen again. I would buy
It wasn't specified by the manufacturer, so I will have to double check on that for you. I will post the update within next few days!
so any updates? thanks!
Any updates?
Are these pretty much identical to the Bushwacker's?
They are similar but I believe they are different? Be nice to know, I've been wanting these for a long time
1 - 8 of 8 Posts
