Just added BFG K02's 275/70/R18 to my stock rims. I'm digging the look and ride so far.
Any pictures of the whole truck with them on?Just added BFG K02's 275/70/R18 to my stock rims. I'm digging the look and ride so far.
That looks awesoem. Great job on the tire choice and color.limited traction even on the dry pavement & near none existent traction with wet, icy and snow covered roads, P rated, so not great for towing (shouldn't tow at all I think).
So is everyone doing the 275/70/18? They fit with stock wheels but not mods needed for it? Tire rack says the BFG KO2 won't fit the 2017 titan
As, TITANUP2017 has shown, they fit. Just keep in mind that the tires will be taller than factory (excluding PRO-4X) so the odometer/speedometer may be slightly affected; see the tire size calculator below.So is everyone doing the 275/70/18? They fit with stock wheels but not mods needed for it? Tire rack says the BFG KO2 won't fit the 2017 titan
Tire Size Calculator | Discount Tire Direct
Unless it was changed for 2017, the PRO-4X comes factory with 275/70R-18 size tires.I drive a 2017 pro 4x so inshould be good to go?
Thanks guys
Thanks for the heads up. It's only 1 mph affected from 265/70/18 up to 275/70/18.As, TITANUP2017 has shown, they fit. Just keep in mind that the tires will be taller than factory (excluding PRO-4X) so the odometer/speedometer may be slightly affected; see the tire size calculator below.
Do you think a 2017 Pro4X could handle going to a 285 BFG without rubbing?Unless it was changed for 2017, the PRO-4X comes factory with 275/70R-18 size tires.
The A/T3W is a solid tire model as well and it works out well for many. If you need any help selecting the right model for you needs and uses, shoot us PM; we're happy to help!Oh ok. Hadn't even looked yet. Kinda like the look of that Falken AT3W. Looks great.
Depends on the aspect ratio, but 285/70R-18 or 285/65R-18 size tires will work on the PRO-4X, stock.Do you think a 2017 Pro4X could handle going to a 285 BFG without rubbing?
