1 - 20 of 155 Posts
Preface:
Thanks to some others who had the guts to try this out, and prove that it works!
If you have a Titan without Audio Steering Wheel Controls, but would like to add them. You should be able to.
This should work most all SE's and most XE's. The only configuration that hasn't been proven yet, is an XE or SE with the single disk black stock radio. If you get one to work, let us know. I think the wiring is there, I just don't know if the single disk radio is compatible with steering wheel controls.
Here are some other threads about steering wheel controls:
http://www.titantalk.com/forums/tit...48-adding-stearing-wheel-audio-controls.html?
http://www.titantalk.com/forums/showthread.php?t=26741
You can get the part from your favorite Nissan Dealership
or order it from one of the vendors.
The part number is : 25552-8s210
Thanks to SickWhip for proving it Could be DONE!
Even though his dealership said it couldn't be done!
Thanks TitanJim for install info that helped me get going.
STEP 1 Getting Started:
Order the part! It should run about $70 to $90. Get your tools.
Go over all the instructions, Also Check in Step 3 ahead of time to make sure you
don't have a security bolt.
You will need the following:
1. Audio/Cruise Combo Controls
2. Socket with 6" or longer extension
3. 19mm Socket and 10mm Socket
4. Torx T10 and T20 or possibly a (T9, T25 rare) Driver or Bit
If You need a Torx set that will work, Sears has one for $4.99
5. Optional - Steering Wheel Puller ($12 - $14 at Autozone)
You can always buy one, and if the wheel comes off with ease, then
return it.
6. Tape (Example Scotch Tape)
Discussion Starter #2 (Edited)
Step 2 Safety Precautions:
- Get your Titan on a nice flat surface, and park it with the steering wheel
and wheels straight ahead. This is VERY important!
- Set your parking Brake!
- Use the 10mm socket to remove the cable from the negative terminal on the battery. Use a rag or something to wrap around the loose cable so it doesn't go sparking into something.
- Now set your timer, clock what ever for 8 Minutes! Important Step! We are dealing with explosives here..
Step 3 Remove Side Bolts from Steering Wheel
- If you look behind the wheel you will find a little cover on each side, you can pop these off with your finger nail.
- Behind these you will have a 10mm bolt. According to the manual it is supposed to be a Security Bolt. Mine wasn't it was just a plain 10mm. So
you may have to find a security socket if you run into problems here.
- Remove the bolt from either side. If it falls off into the steering wheel, it is no big deal you can recover it at a later step.
Step 4 - Remove Air Bag
- Okay you did let 8 minutes pass right, since you unhooked the Battery?
We don't want you blowing yourself up!
- Once the bolts are removed from the previous step. Carefully slide the
airbag out. The mechanic manual recommended working from the side, in the event that the bag ignites. Your probably really safe, but just pay attention
to what you are doing.
- The Airbag will be attached to:
- Green Wire (Ground) Unhook this
- Two Air Bag Connectors (One Orange and One Yellow)
- To remove the Air Bag connectors. Pry on the little black part upwards
away from the airbag, with your fingernails, the little black part will lift up
like a little handle. Once it is lifted, the connectors will easily come off. NO YANKING necessary.
- To get the Green Wire off, there is a little PUSH this on one side
- Also unhook the BUS connector as shown in the illustrations.
- At this point, the airbag should freely come out. Place it face up
outside of the vehicle and away from people or pets. The reason for it to be face up, is if it blows it will just pop the airbag (Less harmful) than if it where to blow facing the otherway, where it would become a projectile. :teeth: In addition you don't want to scratch up the face of it anyway!
Discussion Starter #4 (Edited)
Step 5 Remove Steering Wheel
Now that the airbag is out of the way. We can get to the steering wheel.
Slow down and make sure you read all of these instructions before you proceed.
I went along hellblazing thru this, and when I yanked my steering wheel off, it snagged a wire and ripped the Wire Spool out too! You don't want to know how expensive and what a pain that was to have fixed. Learn from my mistake and go careful, okay!
- Okay again make sure you have the steering wheel straight ahead with tires straight ahead.
- Remove the center Bolt. It is 19mm. You will need a socket extension to remove it properly. You may have to rotate the steering wheel to get it to LOCK into place so that you can get leverage on the bolt.
- Once you get it started, Unlock the steering wheel Using the Key, and turning the wheel Out further, and let it return to the neutral position before continuing. Then remove the bolt.
- Once you have the bolt out. Look closely at the Mark on the Shaft and the base around the shaft for the alignment marks. THIS IS VERY IMPORTANT YOU DO THIS. They may not be pefectly aligned. If it is a couple notches one way or the other, you will need to remember this, and put it back this way. Otherwise when you get it all back together. You are going to be driving straight down the road with your wheel aiming for the sidewalk.
- Now to remove the wheel, I recommend going slow. The first time I yanked it off by hand and it ripped the ribbon cable assembly open (THINK BAD) The second time I did it, I was prepared with a Steering Column Remover Tool. This allows you to slowly control the removal and make sure no wires get snagged.
- As you back the wheel off, be sure to feed the Yellow and Orange wires though there holes.
- Also put your hand thru and hold the spiral assembly in place so it doesn't fall out. Try to not let it spin much either.
- Once you have the wheel totally free. Tape up the spiral assembly as shown.
Discussion Starter #5 (Edited)
Step 6 Removing Old Controls
- Take the steering wheel to a desktop and grab your Torx with T10 and T20 bits.
- Use T20 To remove the three screws on the Back.
- Lift the Back cover off
- Now use T10 to remove the two screws holding the Cruise Control and blank
faceplate on.
Discussion Starter #6
Step 7 Adding New Controls
- Well we are over half way there now! Good Job! :hat:
- Adding the new controls is pretty obvious. It will be reverse
of what we just did when we removed the old ones.
- Don't screw down the screws too tight! This is plastic after all,
you don't want to crack anything!
Discussion Starter #7
Step 8 Reinstalling Steering Wheel
- This is a little bit tricky, but simple process.
- Feed the orange and red wire clips back through. On opposite sides as shown.
- As you start to get the steering wheel in place. Remove your tape, again utmost care to not let that thing spin too much or fall off.
- As the wheel goes on. If you look at the steering wheel from the top you will see that the White Rubber Foot on the Spool, will fit into a recepticle on the back of the wheel. this is shown in one of the pictures below.
- Make sure you get the steering wheel aligned back on the shaft as you remembered it. And make sure it seats all the way down. You can tell that it is seated all the way down by comparing my pictures to your situation. When it is all the way in. You will see metal flush with both the shaft base and the grooves grabbing it from the steering wheel. I don't know how to phrase that better. But it should be flush. I had to realign it a couple of times to get it to seat fully.
- Once it is seated fully, check again your alignment.
- Now you can put the center bolt 19mm bolt back on. You may have to lock the wheel up to get it tight. Don't go mad crazy on the torque.
Discussion Starter #8
Step 9 Reattach Airbag
(Your Battery should still be unhooked!!)
- All most done!
- Reattach the airbag. Orange and Yellow Clips, no problem
- Slide the Green Wire back on.
- Plug in the Bus Connector.
- You can route the wires into the little notches provided.
You want to use them the best you can to keep wires clear
from when you are blowing the horn. You don't want the wires
getting friction burns and rubbing down becoming exposed. :teethmast
- Push the airbag back on it should easily go in. You shouldn't have to force it. Put the two 10mm bolts back in on each side of the back of the steering wheel. Don't go nuts with the Torque.
Discussion Starter #9
Step 10 : Finishing Up
- Put the plastic covers on the back of the steering wheel.
- Reattach the negative battery terminal with 10mm socket.
(I removed the radiator overflow cap here (Be sure truck is cool)
To get better access to the battery socket.
- Start the truck. Check your audio controls on the steering wheel.
You will have to reprogram your stations. But wait to do this after you
take a test drive.
- Test drive, you shouldn't have a airbag light. And your steering wheel
should be straight while driving straight. If it isn't. You will need to adjust.
(Be sure to unhook the battery, and let 8 minutes pass before taking the wheel off again)
Be safe. This is a easy job. I did it in an hour and that included taking these photos. If you can handle a brake job, you can handle this. It's less messy too! If you still want the audio controls but don't want to do it yourself. The dealership should be able to help you out for about 1 hour labor.
If someone does this job in the future and has a digital camera handy. Take a photo of the way your wiring is seated, if it is. (mine wasn't from the factory) I would like to have reference to how the wiring should look like.
:haveredfl
Do u have to wait 8 minuties or AT LEAST 8 minutes with the battery off...also cant u just take the fuse out for the airbag? Thats what they say to do when like installin a body lift and u have to mess with cuttin the radiator brackets and such up front...Ive read the instructions and seen a body lift installed, never done one myself and I already have these controls came stock but just to clear up for someone else... :cheers:
Discussion Starter #11
According to the Official Nissan Titan manual it says in very bold type to unhook the battery and let 8 minutes pass.
Sickwhip where did you get you audio controls from as I will be attempting this task when I get home from offshore and would like to order the part out here. Thanks for being such a good guinea pig and Elbo for the step by step instructions. Ya'll really are some ground breakers.
Here is the part online for $61.09. I just called my dealer and told them the part was that price online and he just made sure the price was over his cost. Then he ordered it and gave it to me for $61.
http://www.trademotion.com/partloca...=2005&graphicID=3630230&callout=4&catalogid=2
Great writeup Elbo....very well done and the pics are first rate!! This type of information is what makes forums great. I am sure we all appreciate it - it takes a lot of effort to perform some of these mods and EVEN MORE effort to document them and post them on a forum. THANKS for going the extra mile to help people you don't even know! :cheers:
Banned
What about the wiring connections for the new audio controls? Are they built into the wheel and no new connections required?
Discussion Starter #17
The connection should be in all Titan's. They use the same shaft and wiring going up the column in all Titan's as far as I can tell. Altough in some trucks it may not be hooked to anything at the other side. If you have a 6 Disc, or RF it should just be plug and play.
Banned
Yeah, i have an 06 SE with the 6 disc. So i just order the part, which comes with the cruise control section, even though i already have that, and install it in the wheel, plug and play, and im good to go?
1 - 20 of 155 Posts
