Just bought a brute force cold air intake. Want to install myself. Any snags I will run into or is it a pretty smooth install? Im fairly smart when it comes to vehicles so im going into it knowing things. Any help?
Instructions tell you to remove the washer fluid bottle. You dont have to do this. You can avoid this by just pulling up on the box in order to let the bolt slide through the grommet on the stock intake box (step where this applies is in the how-to i linked)
You can also skip attaching the small screws to the fender (when it tells you to remove the fender liner). Some people on this forum recommend just buying zip ties and running them through the holes instead of zip ties.
