forgot to send you this lnk in my last PM. fuel rails in the ruff.
Fuel Injection
i dont think your gonna find bolt on ones.
Fuel Injection
yeah I kinda figured that one. I can not find any parts for this motor except parts that wont work for me. I will look at welding 6 an fittings to each and of the fuel rail, or eliminate the cross over and weld 6 an fittings on and use that as the feed to each rail and run the stock fuel inlet to the FPR since my fuel will not OEM Titan fuel system.forgot to send you this lnk in my last PM. fuel rails in the ruff.
Fuel Injection
Cut the OEM fuel inlet quick connect pickup off the rail and smoothed it out. A small piece of plate steel will be welded over the hole. (be sure to de-burr the inside of the rail after any drilling.)id like to see what you did.
