1 - 6 of 6 Posts
Does anyone know if you can buy a DVD player and Monitor that will hook directly up to the AUX function on the radio. Also do you know if you can by aftermarket wireless headphones that will work with the factory system.
Don't know, but I'm sure a stereo shop could hook it up.
This is the mfg that leer used for their titan project. Not sure if they connect direct or even if they wires are even run up to the overhead area if there isnt already a dvd system there.
http://www.savv.com/products_over_1050.htm
The project link:
http://www.leer.com/titanproject.html
I eventually plan on putting headrest monitors in for the backseat passengers. This mfg seems to be the best for oem fit and finish (they currently havent finished the titan system yet)
http://www.vizualogic.com/headrest_prod/kits.html
I am not as deep in the pockets as some of you folks(ie LE Crew Cab) so I Bought a 7" Portable DVD Player. It plugs in to the 12 Volt outlet and works great. A mini plug cord will then hook from the player to the stereo aux jack. Walmart had the player for only $189 and can use it other places too.
:cheers:
1 - 6 of 6 Posts
