Ok, here's the short version.
Hella 500 Series Driving Lights
Basically have all the wires ran
Still need to ground fogs
Connect Power to fogs
Hook up Switch
I have the relay hooked up as shown in the diagram. Here is my question though. For the switch, I've got the yellow wire coming from the relay, and the instructions say to tie the other (green) wire into the high beam power source. I want these lights to operate completely independant of the high/low beam system. What do I do with this green wire??? Obviously, it needs some type of power coming to it, correct??? I assume that I can't simply run it back to the + terminal on the battery though, can I??
Thanks.
Hook up Switch
Thanks.
