I have an aftermarket radio problem. In my 04 Titan, I am installing an aftermarket radio. I got the correct adapter cables and soldered all of the wires with shrink wrap to prevent any shorting. After connecting the radio to test it, I have no sound on either tuner or CD. I called the tadio's tech support. After telling them my stock radio had a 6-disk CD changer (that doesn't work) they said I probably had a high wattage amp and that my radio's 4 watt output just wouldn't put sound out of the speakers. The tech said I'd have to run speaker wires directly to the speakers. To test the radio for sound, I put straight pins through two of the speaker wires (to the same speaker). I put on a headset and touched the pins to the headset mini jack and heard music playing. So the radio does output sound.
My radio has a pair of amp outputs but I don't where the cables go to the amp. Has anyone had a similar problem, or successfully installed a low-end (less than $100) radio in a titan replacing a radio with a cd changer? Where is the amp located?
