Aftermarket tow mirrors
1 reading
8.9K views 8 replies 4 participants last post by  SteveL
#4 ·
Nice, I wish they had the cameras in them. I didn’t really care for the 360 cameras when I bought it, but after having them they sure are nice.
For my f150 I had a nice set of slip on tow mirrors that worked fantastic, but they don’t make them for the Titan. All we get is the crappy strap on mirrors. They work, but they suck.
Thanks for being the guinea pig! I hope they work out for you! I’m sure lots of other folks will follow song… this seems to be a mod a lot of people ask about.
#5 ·
I've wanted the bigger mirrors from the beginning, but I never was willing to fork out the $$$ for OEM, and there was nothing for aftermarket options. Then I forgot about it for a while. A couple of days ago I just happened to scroll across a Facebook ad that reminded me, so I checked again and found these. I hope they work out. Even without the blind spot sensors they will help reduce/eliminate the blind spots I have, so as long as the quality is decent I think they should be worth it.
#6 · (Edited)
I finally received my mirrors and got them installed today. There was a wait because they were on backorder when I originally ordered them. Anyway, my initial impression is that they are good to go. Removal of the stock mirrors and installation is pretty straightforward, even if you are not mechanically inclined, like me. Note that you do have to remove the door panel to access the wiring harness. They seem to work as advertised. They adjust properly and the turn signals work. They slide in and out with a little effort. It's not particularly difficult, but they seem secure enough that they won't be bouncing in and out while driving. The only thing that disappoints me a little is that the puddle lights do not work. I read that all Titans were pre-wired for puddle lights, whether your truck came with them or not. That is apparently not the case, as these mirrors have puddle lights but they don't work on my truck. They also include blind spot sensors, but my truck does not have that feature so I knew they would not work going in. Overall I think I will be satisfied with them. I'll report back after I've driven with them for a month or so.
#7 ·
they look identical to my 17 sv tow mirrors. i wonder if you disconnect the battery for a little time, while the system pick up the puddle lights once its hooked up? i don't know if lights work like that, is why i ask
Reactions: SteveL
