Going to install some used tires I bought soon and get aligned but I just remember that since the rims are being dismounted I should probably buy new tpms sensors. That bright yellow indicator light is annoying. Will any aftermarket replacement do? Also I've never bought any before and when I was at Americas tires awhile back I noticed that you need a specific one depending on the psi you run in the tires as they are also rated? Is it worth the hassle to replace them?
