Aftermarket Upper control arm questions
1558 Views 3 Replies 3 Participants Last post by  loufish
I Installed a 2" leveling kit in my new 07 4x4 and the upper control arms are hitting the coil buckets. I'm looking into purchasing a set of aftermarket upper control arms.
My question is if I add the aftermarket control arms where would I find replacement joints when they wear? I see most of the aftermarket arms use the same stlye joint that replaces the factory balljoint. Are the joints easy to replace in the aftermarket arms?
Thanks Mac
Most performance replacement upper arms use a 1" uni-ball bearing, which has a snap-ring to hold it in place.
They are replaceable.
i have the same problem, where did you get your arms
I highly recommend:
http://www.prgproducts.com/titan.php
Contact Greg, tell him what truck you have, and what you want to do with it...He'll give you your best options and won't sell you junk or something you don't need...
