Not sure of the date, but it's possible that your buckets are positioned on the frame where you would still have an issue even if yours are the later version, since their location can vary a lot. With the newer '08+ Titans, having contact is even more likely, but the later PRG's are going to provide more clearance than the Total Chaos, RC, or original PRG's.Just like NorCal I had to Dremel my coil buckets. Even after taking about 1.5"-2" off, it will lay across when the the wheel is at full droop.
So when did the new rev. of PRG UCAs come out?
Or fords, chevy's ?? they had to make it the stupidest design in the world.why didnt nissan design them like the tundra's? like really.
I was looking at my dad's tundra today, the coilbucket is similar to our set up, only its like they looked at the titans and were like, that long coilbucket is gonna hit, lets make it nice and short. If you cut like 3 inches off our's it'd look like the tundra. But who knows how it would hold up since it wasnt designed like that.Or fords, chevy's ?? they had to make it the stupidest design in the world.
That's a big negative. They are still manufactured and you can buy them today.The only Total Chaos arms you're gonna be able to get are used ones, as they have discontinued any parts they made for the the Titan. Quality stuff, however PRG really took a firm grip on that segment of the Titan aftermarket.
Also, I do believe that the PRG arms offer more clearance.
Get them done ASAP so I can order a pair :teeth:I am designing a pair of boxed ucas that I should have finished by the end of this week. The boxed arms allow for more clearance than that of a tubed and I will find out once I weld them up if the measurements worked out correctly. Once they are fine tuned they will have better clearance than that of the tubed arms out and plus boxed arms look nice![]()
please keep the price competitive so the "normal guy" could afford them. I have seen your work and would def be down for a pair if the price is right.I am designing a pair of boxed ucas that I should have finished by the end of this week. The boxed arms allow for more clearance than that of a tubed and I will find out once I weld them up if the measurements worked out correctly. Once they are fine tuned they will have better clearance than that of the tubed arms out and plus boxed arms look nice![]()
x2. i think i have first dibs lol:hat:Get them done ASAP so I can order a pair :teeth:
I'll be watching for news of these!I am designing a pair of boxed ucas that I should have finished by the end of this week. The boxed arms allow for more clearance than that of a tubed and I will find out once I weld them up if the measurements worked out correctly. Once they are fine tuned they will have better clearance than that of the tubed arms out and plus boxed arms look nice![]()
