Do you still have TPS in aftermarket wheels: yes/no?
1 - 12 of 12 Posts
So I'm having a bit of trouble with my Rockstars. I went from losing pressure fast to slow after retightning them down. But they still seem to lose air at about .5psi a day. I'm checking them every day at the same time to avoid any inconsistencies due to ambient temperature. I'm getting to the point of saying the hell with it and remove them. How many of you guys are still using your TPS in aftermarket rims? Also did any of you have issue like mine?
Did you replace the gaskets before you swapped them over? The tire shop may have screwed them up installing them. If they don't get the gasket in perfectly, it will leak pressure.
I have my TPS in my Mojave's and have no problems with losing pressure.
Yea, they had to use new gaskets because the originals were too small for the KMC's
They may not have seated them properly. Is the air getting past the seal?
Yea, really slowly. Even if you do a soapy water spray you wont notice the bubbles unless you look really closely.
I didn't realize rims have different size stem holes.
I keep a spare sensor, gasket and nut in my toolbox. If I ever had a real bad flat and destroyed the tire and broke the sensor, I'd hate to pay twice to have it put in.
I Wish they could be programmed by a push of a button by the user, instead of paying the dealer to do it. Not a well thought out system IMO. Too dealer centric.
damn, another 1-2psi loss all around since Saturday.
I don't have them, and don't miss them. The low pressure warning light doesn't go off (for me) until exactly sixty miles on the odometer, then you have to deal with the light being on. As soon as you turn the truck off, the light stays off until you go another sixty miles or so.
I, personally, think that TPS' are a joke and just something else to cause headaches, just like you are having. There is no need for a Tire Pressure monitoring system on any vehicle. We only have them thanks to those morons out there who fail to ever check ANYTHING on their vehicle, let alone the tire pressures, much less do a "walk around" before they hop in and take off down the highway. Rant over!
Well, made another appointment for tomorrow. I'm gonna give it one last try, then I'm ditching them. What a pain.
Thats the same reason we have power robbing smog equipment, for those same idiots that do not maintain their vehicles. Just gas and go. I'm surprised that half of them actually remember to change their oil!
Personally, I like the TPS system. It reminds me to air back up after my off road expiditions.
I think you should get rid of the rockstars and go back to oem so you can keep the sensors. Then I'll do you a favor and throw you a few bucks so they aren't wasting room in your garage. LOL.
Discussion Starter · #12 ·
sure thing, you wouldnt happen to have any magic beans for sale too would you?:rofl:
1 - 12 of 12 Posts
