Same problem I was having. That's how I ended up with my K&N intake kit. I actually got really pissed after fighting it for an hour and "accidentally" put my fist through the top of the box, trying to get the lid to go in all the slots.
You're absolutely correct. I started laughing reading about the filter problems. When you put the lid on, just use your fingers to guide the tabs in, this isn't rocket science.54warrior said:Just push down on the tab and it will snap into where it needs to go.
You know what, nevermind..sudden urge said:You're absolutely correct. I started laughing reading about the filter problems. When you put the lid on, just use your fingers to guide the tabs in, this isn't rocket science.
hmm... that stinks.. I wonder if Kman is on to something with expansion from the filter??billaj said:I'm going to go back again and try to mess around with it. I have the K&N air filter in it right now, Faith+1. I had just taken it out to clean it and noticed when I put it in the middle prong was being a little devil. LoL
Use your fingers to push down on those three guide tabs as you wiggle the lid back and forth till it slides all the way in. The center tab is the one that hangs up, just push that tab down and the lid will go all the way in and close properly.FOURRUNNER said:Man I am having the same problem.Ijust installed a K&N filter and now the lid wont close.Its almost closed but not all the way.What can happen from this?/Can i leave it like it?
