Not sure what your question is but the fire stones have a larger load capacity and are easier to install but don't ride as nice and don't have as good of customer service as the air lift set. Air lifts require drilling into the frame and ride nice. Air lifts have a larger travel range and ride a little softer. I tried installing the fire stones first but they would not work with my dual exhaust. I have the air lifts and they work great. I tow about 3500 lbs with a heavy tongue.I have a 2005 Nissan titan Le. The front has R/c uppers 4x4 struts and 2" spacer. The rear has shackles 1" blocKS and Bilstein shocks what would work best with the lift. I will be towing around 6000lbs
