My passenger side right air vent has broken. What I mean is the blades that change horizontal direction cannot be controled by the wheel anymore.
Does anyone know what and how to remove the dash pieces to get to the air vents?
Happened to me too, if you're still under warranty it's covered.
Have the same problem, just haven't had time to look at it.
I bought my truck used too. Factory warranty carries over if you're still under the limits...otherwise nevermind.
Discussion Starter #7
Got the vents out and realigned the blades.
It took a while to realign and snap the blades back in.
I eventually used a small flat blade screw driver to push the blades back into position.
