Trimmed the screen off the throttle body gasket, other then that, bolt on and ride.smokeum said:
Trimmed the screen off the throttle body gasket, other then that, bolt on and ride.smokeum said:Those who have installed the Airaid throttle body spacer... I was reading where you may have to adjust the cruise or kickdown cable??? Has anyone had to make an adjustment or did you just bolt it on and ride?
Make sure you want to keep the t.b.s. before you go cutting stuff. I had no benefit from the spacer so I uninstalled it.smokeum said:I'm going to have to mod mine some. I installed the spacer but my tube from the CAI is pushing into the fan shroud. Its a tight fit even after I unbolted the kit and tried to reroute it some. Looks like the only way mine is going to fit is if I cut the tube about 1/2 inch where it goes into the t.b.
