So after I had a level kit installed I got an alignment done. Since then, I just added larger 20" wheels/tires which really shouldn't change my alignment. For reassurance I just got a free alignment check and surprisingly my caster, camber and toe was all out wack in the front. They said they could fix the toe easily, but that I would need a caster/camber kit because the 2017 Titan doesn't come with adjustable cam bolts. So I had them hold off till I did some research on what exactly I need. Cam bolt kits are available for about $50. I guess my questions are, what is the difficulty of installation so I can gauge labor cost? Are cam bolts even necessary for just a level kit if you can just adjust toe for proper tire wire? I'm not knowledgeable in this arena so could use some help. thanks in advance
