The stock setup will adjust camber and caster, but only together. Because of the design of the Cam-Bolts that are in the lower arms, when you go to adjust camber, it will adjust caster at the same time, and visa-versa, but not always in the way that you want it to.Great info, CVTitan05. Thank you. To further my understanding, is the stock setup adjustable for caster, and if so, how is it adjusted? I like to know these things before I ask my tech questions so I can at least ask intelligent questions. Thanks again for the great info!
