So I have searched and found no straight answer to this ?......If I lift my truck with more than a leveling kit on a 2006 then I need the camber bolts?
YES, without a doubt.jasonator said:So I have searched and found no straight answer to this ?......If I lift my truck with more than a leveling kit on a 2006 then I need the camber bolts?
Let me make sure I understand correctly, the front wheels are rubbing on the rear portion of the fender well, in front of the driver/pass. doors. That issue is commonly solved with the "Pinch Weld Mod"iamfireman said:54warrior, maybe you can answer this for me. I have an 08 Titan with the 6 in. coil over Pro comp lift. I was advised at the first service to have the suspension checked and realigned. I have always had since I purchase it the tires would rub on the rear wheel wells on hard turns, but now after the alignment, the right front tire doesn't rub the rear, but rubs the front bumper on left turns, has a slight drift to the left and pulls to the left when I apply the brakes. Looking at the tire, it looks like it was moved forward within the wheel well. I had them recheck the alignment and they say everything is good. I know something is wrong, any ideas?
Thanks!
Stage 1 or Stage 2 PC Lift??ZMoney520 said:I have the same issue as IAMFIREMAN. I put the pro comp lift on 4 weeks ago with 35" tires. The left tire rubs the front fender and the right tire does not. With the tires pointed straight, the left tires has about 2 inches clearance from the front fender and the right tires has 3+ inches. There is a big difference in the location of the wheels in the wheel well. I have also had the front end aligned 3 times and it is getting it's 4th try today. The truck continues to pull to the right and the last adjustment they made must have had it to the limit because it popped and cracked when I left the tire place. It sounded like the front end was going to fall off.
I have a question about the lower a arm. When it is mounted to the new cross members and the cam bolts tightened to spec, there is a gap between the cross member and a arm. Not sure if that makes sense, but the gap doesn't go away when tightening the bolts. Is this normal? It seems like when I take off it shifts because I get some kind of noise when going straight and taking off.
Not sure about it all but right now I am not to excited about this lift. I have a new truck with 3000 miles and it pops, cracks, pulls to the right and rubs.
If they removed caster on the R/F wheel, that might bring the wheel slightly forward but that would make the truck pull / drift to the right unless the caster was adjusted with the lower arm.(not sure of the kit you have) That would bring the tire slightly forward when adding caster. I always add about 1.5 to 2 degrees more positive caster on the right side to make up for the crown of the road. If they have a large difference in side to side caster,( 3 or 4 degrees) this will cause your pull.iamfireman said:54warrior, maybe you can answer this for me. I have an 08 Titan with the 6 in. coil over Pro comp lift. I was advised at the first service to have the suspension checked and realigned. I have always had since I purchase it the tires would rub on the rear wheel wells on hard turns, but now after the alignment, the right front tire doesn't rub the rear, but rubs the front bumper on left turns, has a slight drift to the left and pulls to the left when I apply the brakes. Looking at the tire, it looks like it was moved forward within the wheel well. I had them recheck the alignment and they say everything is good. I know something is wrong, any ideas?
Thanks!
gnonice said:If they removed caster on the R/F wheel, that might bring the wheel slightly forward but that would make the truck pull / drift to the right unless the caster was adjusted with the lower arm.(not sure of the kit you have) That would bring the tire slightly forward when adding caster. I always add about 1.5 to 2 degrees more positive caster on the right side to make up for the crown of the road. If they have a large difference in side to side caster,( 3 or 4 degrees) this will cause your pull.
More caster, heavier steering, better "return to center feel" after turning, better tracking. I was thinking there was an adjustment with the lift kit that was installed?? Tell ya the truth, I only had to adjust the toe after I installed my leveling kit.54warrior said:
Someone correct me if I'm wrong, but there is no caster adjustment on the Titan. Only toe/camber. Caster is the relationship between the top and bottom ball joint, and there really is no way (that I'm aware of) to adjust that. Certainly with the 'built-in' slop that Nissan made on the lower control arms, there will be slight caster change if/when the lower arms were to move fore/aft. In order to change caster, the location of the upper or lower ball joint would have to change.
More caster = better high speed handling
Less caster = better slow speed handling (twitchy at high speeds)
Interesting!!! Good info to process!!!gnonice said:More caster, heavier steering, better "return to center feel" after turning, better tracking. I was thinking there was an adjustment with the lift kit that was installed?? Tell ya the truth, I only had to adjust the toe after I installed my leveling kit.
On many vehicles, you can adjust the upper or lower control arm (pivot) front to rear via cam bolts, etc. Again, I've never aligned my Titan (let alone installed a lift kit) so I'm not sure whats there. On my GM there are cam bolts that let you move the front of the upper arm different from the rear of the upper control arm, in effect changing the ball joint center line. Kinda like the "old" RWD cars with shims. Same theory. Move the front of the arm outward & the rear of the arm inward (via shims or cam bolts) evenly increasing caster while not changing camber. Moving unevenly will cause camber to change also.
There is caster adjustment on the Titan, and is done with the same camber bolts. For camber both the front and rear bolt are turned in for more positive, or both out for more negative camber, and the caster is unchanged.
90-6410Btitanss said:I know this is a old thread.
Does anyone know the part number for the Pro Comp Camber Bolt Kit?
I lowered my Titan and need the Pro Comp kit because it has a little more range of motion, look's like 3* compared to the stock 2* bolts.
