I have a Crew Cab with the mid-line system.
I'm not quite ready to buy the deck I want just yet (not 100% sure what I want and have too many other things to spend money on right now). BUT the OEM setup sounds pretty bad.
I had an Alpine CDA 9827 from a previous vehicle (cheap no frills HU, but solid), so I threw that in first with no other changes (btw I used the Metra install kit - I hate the chassis that is sits in, and will eventually fill & repaint the bezel to get rid of the plugs, etc).
With nothing but the Alpine HU, there was a HUGE improvement over the stocker. BIG difference.
This weekend I installed some 6.5 components in the doors and replaced the tweeters, putting the new Infinitys right in the OEM location. I used strap-metal to create an "x" mount for the tweeters and it was the oddest thing - the holes from the strap metal lined up PERFECT as if it was an OEM setup. I used the factory push-pins and dropped them right in.
My point is, after just a HU change and a 6.5 front speaker component change, the audio is TONS better than what it was. HUGE difference. There's tons more I plan to do, but time isn't abundant.
If anyone is sitting on the fence to make some audio upgrades, it doesn't take much to improve greatly.
