Before I start tearing things apart, does anyone know if the front driver side axle has and movement in it. My axle moves about an 1/8 of an inch. The oil gasket is good and the u joint is tight. Much like the 2 other recent posts my truck is howling down the road at 40 + mph. I checked the wheels for bearings a there is no additional movement in the wheels, although that still could be the noise. I would rather have bad wheel bearings than a bad differential. Does anyone know if there is an expectable amount of movement in the front axle?
