Hey Gang....just want to share my recent install experience. i'm a "new" member been lurking off and on forever. So my 04 succumbed to the dreaded Manifold cracking so i went with the obvious best choice and got the awesome JBA LT, Cajun B pipe, Uprev set up from Cajun Bpipes (thanks Guys!). Jeff recommended the tried and tested Vibrant resonator. Honestly i forgot to include it in my order....I figured i can always add it. based on a previous install of a Synapse Engineering antidrone pipe i installed on my Turboed SE-R and how well it worked there i figured id give it a go on the Titan. I went cheaper and bought 2 2" Ubends from JEGS and made my own 18" long Antidrrone tubes. I have the Banks catback. after some test fitting and placement checking i removed the catback Y pipe and went to drilling and welding. as those of you that have this setup know, the Titan turns into an angry beast on steroids especially when you start it up
. I drove it a bunch to collect logs for Joe to do the tuning and was less than pleased with this new found level of exhaust sound.
After i installed the setup of the AD pipes i described above i reluctantly went for a 60 mile RT to the airport to drop off my daughter. She was like wow dad the truck sounds great! (she was my test and tune riding buddy
). Overall impressions are there is no cab drone at 65-80 MPH and the full throttle runs that used to vibrate the dash to the point i thought the plastic would shatter is gone! Im going to include a couple pics but i want to preface that with I DO NOT weld for a living
. The goal with this post is NOT to take away from any of the hard work and testing lots of you guys have done to get rid of Drone but to perhaps help with some viable options. Questions and comments encouraged....Be nice!
Terry
Terry
